Bizhub C454e with Fiery IC-414 || MFP error code C-FD30
  • kmtechsjj11
    • Sep 2014
    • 4
  • kmtechsjj11
    • Sep 2014
    • 4
    Re: Bizhub C454e with Fiery IC-414 || MFP error code C-FD30
    swapped the HDD on the fiery, reflashed system code 1.2 ... still same issue-
    unable to print a config page /any "Print Pages" through the fiery engine - unable to print through fiery driver without blue flashing lights, eventual crash C-FD30.
    • Synthohol
      Certified Konica Expert
      • 5846
      have you replaced the ram on the mfp board yet?
      should be setup LPR port 515 queue name Print
      have you tried running the diagnostics?
      maybe the results will help narrow it down.
      is the marketing area set correctly?
      Related Products:bizhub 224e,bizhub 284e,bizhub 364e,bizhub 454e,bizhub 554e,bizhub 654,bizhub 654e,bizhub 754,bizhub 754e,bizhub C224e,bizhub C284e,bizhub C364e,bizhub C454e,bizhub C554e,bizhub C654e,bizhub C754e
      Related Options:
      Reference
      The Self Diagnostic function conducts diagnosis for faulty memory and various boards in the main body when a trouble code is generated or main body activation failure occurs. The area of concern will not pass the diagnostic test (NG).
      Prerequisites
      Please install the latest firmware.
      Procedure (using SERVICE MODE menu)
      1. Call the Service Mode to the screen.
      2. Touch these keys in this order: [State Confirmation] g [Self-diagnostic] g [Check All].
      3. Press the Start key to start the check procedure.
      4. When the check procedure is completed, the results are shown on the screen. If any of the check results are NG, take measures upon confirmation of the corruption details mentioned above and Next action.
      Note: Press the Stop key to interrupt the check sequence.
      Procedure (using main power switch)
      1. Open the front door.
      2. Turn the main power switch ON while pressing the power key.After a short beep sound is made once, release the power key and close the front door. Wait to display the self diagnosis (full check) screen.
      3. After displaying the self diagnosis screen, press the start key. The self diagnosis (full check) is started. The result of the diagnosis is displayed for every item. (OK/NG)
      4. After finishing the diagnosis for all items, turn the main power switch OFF.
      5. If there is an item displaying NG, investigate the NG item and take countermeasures.
      Individual Diagnostic Checks
      Check mode Check details Corruption details Next Action
      Note: For additional detail please refer to the Adjustment/Setting section of the Service Manual g 12. Service Mode g 12.18.12 Self-diagnostic.
