Konica Minolta C364/C284 Fuser Unit and Transfer Belt Reset
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta C364/C284 Fuser Unit and Transfer Belt Reset
    Hi
    How to reset Fuser Unit and Transfer Belt life in Konica Minolta C364/C284.
    Many Thanks
  • myster
    • Oct 2011
    • 79
    Re: Konica Minolta C364/C284 Fuser Unit and Transfer Belt Reset
    Service mode- Counters- life- new relase- fuser - ok- with from cover open
    • mearmi
      • Oct 2010
      • 350
      It doesn't reset
      did it 3-4 times
      • copyman
        Owner / Technician
        • Sep 2005
        • 4724
        Are you doing it with front cover open?
        • rrrohan
          • Sep 2011
          • 1977
          Originally posted by mearmi
          It doesn't reset
          did it 3-4 times
          selectwhatyouwanttoresetthenhitthestartbutton.ifit snotblueyourdoingitwrong
          • HitMan
            • Aug 2015
            • 170
            Are you opening the toner cover or the bigger front door panel?
            When first entering service mode press stop 0 clear then set the fuser transfer to no stop? There are some bit switches that may also need to be changed.
            • mearmi
              • Oct 2010
              • 350
              Yes after opening the front door.
