you are so right redime ,thanks
bizhub 350 whit frayed drums
copiertechjack
So whats is the fix for this problem?
Developer unit?
Developer?
Drum?
Transfer?
We have a machine at the moment showing the signs, how do you suggest we address the problem from here?
ThanksComment
Problem was Transfer roller. This last drum survived all 100k copies after i put new trans. roller. Now i replaced the drum but this time i affixed plate that is covering transf. roller avay from roller it self and i removed plastic supports that rise corona level position. Will check machine today.Comment
So just so I understand what is happening, the transfer is effecting the drum which then effects the developer?
ThanksComment
