KM Cxx4 or newer // ignore driver paper type setting
  • Gift
    • Mar 2011
    • 2459
    I have a customer using different paper weights / types and since the IT + software end is a bit tricky it would be great if I could only set up these paper settings only MFP wise. I know from Ricoh a setting called "auto continue" i can change to "immediately" so there's no pop up when a paper type mismatch occures. In this case the machine treats the paper with the settings stored MFP-wise.
    Any chance to do this trick with a KM MFP?
    thx for any input
    • 23006
    Re: KM Cxx4 or newer // ignore driver paper type setting
    Not that I'm aware of. The request must match what's available. =^..^=
    • rrrohan
      • Sep 2011
      • 1977
      Why not setup a seperate printer cue that defaults to the customer paper weight and tray
      • Gift
        • Mar 2011
        • 2459
        Might be an option but if you look at the customers shelf there's so much different stuff
        • rrrohan
          • Sep 2011
          • 1977
          well if they have a lot of different stock of paper assuming thats what you meant by that comment maybe its best its not set at the copier
          least your customer sets correct paper type, the amount of customers i get "well i have 180GSM paper but copier does max 163GSM so i set it to that but its smudges"
          what i tell my customers who do envelopes from bypass tray is tell it to print and then load the media.
          I setup a separate cue for custom paper stock jobs that saves to a user box. that way it wont start until they are at copier loading paper and wont hold up others prints
          Often if you justify the way KM forces things such as saying "it prevents other users accidentally printing on expensive glossy paper by mistake" customers will accept the extra steps
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            This actually CAN be done on the new xx8 series machines but only for the bypass tray. See attached photo. This is from a C258.
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
