C3350 Touch Screen
  • Elmo
    • Feb 2010
    • 541
    C3350 Touch Screen
    Hi all
    Does anyone know if there is a part number for the front touch screen (digitiser) not the whole display
    ive 1 that is playing up i have calibrated and cleaned it several times
    but it still either takes several attempts to get it to react to touch or it just doesn't bother
    i can only find a part number for the whole display
    Thanks in advance
    I Used To Live To Fix Things Now i Fix Things To Live
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: C3350 Touch Screen
    Should be under warranty no?
    • mo0651
      • 1054
      Konica Minolta released a bulletin on this symptom. I am not where I can retrieve it at this time. They are saying it is a faulty memory chip on main board. re-seat or replace.
      • Synthohol
        • 5849
        I just searched SSD and did not see the bulletin.
        You can search on your mobile device Knowledge
        • mo0651
          • 1054
          It was a Tech Bulletin, Said to remove memory module, reboot copier, Op panel should function if it was a bad module. You can leave it out till you get a new one in.
          • darry1322
            • Oct 2010
            • 817
            bulletin 10566 Operation Panel Lock-up
            • Elmo
              • Feb 2010
              • 541
              Thank you for all the responses
              it is less like a screen lock out more like a lack of sensitivity
              mainly the top left hand area
              the screen will respond but it may take 5 or 6 presses in the area to get it to work
              i will look at the memory module later and let you know if it fixes it
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                We have hundreds of these machines in one building - dozens have had the panels replaced already. Failure is not uncommon.
                • Elmo
                  • Feb 2010
                  • 541
                  removed the memory module didn't fix this fault
                  i can only find part number for the whole screen
                  is there a separate part number for the front digitizer screen or do i have to get the whole thing
                  • Konicatech
                    • Feb 2016
                    • 131
                    Whole thing, unit is not supposed to be taken apart.
                    • Claus
                      • Aug 2009
                      • 3
                      We have had a failure rate on touch screens of 75% on the first batch of 12 machines that we received. 9 out of 12 machines (was a very early batch of machines) have thus far had panel replacements. We have found that fw updates did not solve the problem.
                      • D Colour
                        • Oct 2008
                        • 216
                        Hi
                        Would you be able to post or email this bulletin? We have a similar problem with the Olivetti MF3300 and Ive asked technical support if they can get me that bulletin, but they cant!
                        Everything that has a beginning, has an end.....
                        • darry1322
                          • Oct 2010
                          • 817
                          Originally posted by D Colour
                          Hi
                          The bulletin says it's due to the expansion memory. If you remove the expansion memory and the lock-ups stop then replace the expansion memory.
