1St paper tray currently not use .
  • paery80
    • Feb 2017
    • 9
    [Error Code] 1St paper tray currently not use .
    Hiw can I fix this problem
    I check all parts paper feed area
    anyone can help me to fix this problem
    Sent from my SM-J200GU using Tapatalk
    • 14815
    Re: 1St paper tray currently not use .
    I really helps to know the make and model of the machine you are asking about.
    • paery80
      • Feb 2017
      • 9
      Konica minolta bizhub 363
        • 14815
        There is likely paper stuck behind the tray.
        • paery80
          • Feb 2017
          • 9
          Dont have any stuck paper. I checked all sensor and first paper tray motor also all ok
          main problem 1St paper tray not show on pannel
          2 To 4 Paper tray show on pannel and its working better
            • 14815
            Then go into service mode and un-isolate the paper tray.
            • majx75
              • Nov 2014
              • 13
              Also you can remove the paper from the tray and do an "error reset". As long as there is no paper stuck behind the tray, you should be good to go...
              • nikolai2454
                • Apr 2014
                • 6
                Did you fix the problem for that?
                I can help you .
                • paery80
                  • Feb 2017
                  • 9
                  Tnx everybody already I fixed the problem
                  • myster
                    • Oct 2011
                    • 79
                    How did you solve the problem?
                    Thank you
                    • nikolai2454
                      • Apr 2014
                      • 6
                      Follow theese steps:
                      1.Utility
                      2.Check details
                      3.SERVICE MODE: stop >0>0>stop>0>1
                      4.System
                      5.Trouble Isolation
                      6.Tray1 Set to unset
                      Thats all!
                      • paery80
                        • Feb 2017
                        • 9
                        Thanks nikolai
