bizhub c284e with a c-0211
  • brent
    • Nov 2008
    • 1214
    I know in the fs 527 models there was some finisher elevator problems with the sensor stopping the elevator tray from lifting
    what about the fs 534 is there a pretty same solution for this model? I have 2 of them actually with this code..
    trying to locate it on mykonicaminolta is pretty hard for some reason..
    any suggestions?
    thanks all
    brent
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: bizhub c284e with a c-0211
    A C-0211 doesn't even have anything to do with the finisher.
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • Synthohol
      Certified Konica Expert
      • 5850
      manual feed up/down abnormality.
      there are 2 foam wedges that are shipping material, are they still there? take 'em out.
      • brent
        • Nov 2008
        • 1214
        yep I had the number wrong in my head. lol you guys are right.. I was thinking it was a different code
        my bad.. I turned 44 and lost a lot of memory I guess..
        I will look at the manual feed tray up down. thanks
        brent
        • REGSIS
          • May 2016
          • 435
          brent
          Problem is commom. Customer pulls tray while machine is picking up paper from tray and push it back and squeeze the paper behind the tray thus blocking paper elevator motor.
          Pull tray 1. Unscrew stopper on left side of the tray.
          Slightly lift tray to remove it completly.
          Look for paper inside. Easy, 2 minutes of work.
          Edit: if tray 1 is disabled turn off main switch and back on after 15 seconds (or more).
          • allan
            RTFM!!
            • 5462
            Hehe struggling to keep this thread on track.
            Whatever
            • brent
              • Nov 2008
              • 1214
              yes it started out my bad.. and the code doesn't have anything to do with any of the trays but the manual bypass tray..
              here is the problem I went and looked at and even disabled the manual feed tray.. the noise is there. it wont go away no matter what
              so the customer couldn't deal with it.. so with time in mind I took out the gear and clutch from by bypass.. noise went away lol
              I was just curious if anyone else has just had a noise associated with this code.
              thanks all
              brent
              • REGSIS
                • May 2016
                • 435
                My bad too.
                I was thinking about c-0202/c-0204. Fast reading.
                Sorry!
                Had this problem c-0211on this model.
                Strange thing was that user didn't ever use bypass tray.
                I dissasembled bypass tray clean the sensor, unplug and plug in every connector and code never came back.
                Just don't know what caused it.
                Generally speaking (on various models) c-0211 can be caused by inproper clutch or solenoid operation.
