Minolta C452 alignment error A3
  • myster
    • Oct 2011
    • 79
    Hello
    A4 printing is good
    When printing in A3 there is an alignment error at the end of the copy
    Clean laser, clean reg sensors
    SKMBT_C20317030109102.pdf
  • Max
    • Oct 2011
    • 552
    Re: Minolta C452 alignment error A3
    Do you mean colour reg out?
    • myster
      • Oct 2011
      • 79
      Yes vertical is fine
      Horizontal in rear print bad yelow cian and magenta
      • kingarthur
        • 1325
        try FW, had a similar problem & once I upgraded FW it sorted itself, when you do the FW.... DO NOT upgrade scanner FW
        • myster
          • Oct 2011
          • 79
          Re: Minolta C452 alignment error A3 Solved!!
          Solved !!
          Change the speed of the fuser unit
          Service mode machine: Fusing transport speed
          Thank you
