Konica 361 black and white how to reset fuser section
  • DOE
    • Mar 2010
    • 258
    have a Konica 361 black and white that says to replace fuser soon is there a fuse on the fuser section I took off the black covers and could not find a fuse if not how else can you reset it thank you
  • Woxner
    • Jul 2011
    • 848
    Re: Konica 361 black and white how to reset fuser section
    go into sevice mode and system two then scroll to counter reset fuser counter.
    • Woxner
      • Jul 2011
      • 848
      under system 2 inialization then counter. you can reset the drum unit and fuser. drum unit is not the same as reseting the drum. all that is done under parts tab also some fuser part counter there too
