BH350 firmware
  • KMtech69
    • 68
    BH350 firmware
    Hi all
    I'm having a problem with a BH350 that is asking for firmware "load paper in drawer". If anyone still has this firmware I would appreciate it.
    Thank you in advanced
  • mo0651
    • 1054
    Re: BH350 firmware
    So the white lever on feed section is not broken?
    • KMtech69
      • 68
      Re: BH350 firmware
      Yes I have replaced the whole feed unit. It will run 2 or 3 copies then say replace paper.
      • mo0651
        • 1054
        Re: BH350 firmware
        Ahhhh, What color is the plastic latch that is supposed to hold the tray closed? White? There was a mod put out because the tray could actually come out a hair and cause this. also the
        tray could crack at the spot that the same holder is supposed to hold.
        • KMtech69
          • 68
          Re: BH350 firmware
          I Have installed all the modes and updates except for the firmware. I have also held the drawer into position and had the problem happen.
          • Woxner
            • Jul 2011
            • 839
            Re: BH350 firmware
            wewll firmware wont fix that problem. you may have a bad sensor. if you put the new lock on make sre the tray is not cracked where it latches
            • CraigW
              • Dec 2010
              • 417
              Re: BH350 firmware
              Try taking the registration clutch off and spray some IPA down the white plastic gear/cup open edge and spin it a bunch to dry.....then test.
              What is the total counter at ?
