FA14 in bizhub c308
  • Shinigami
    • Mar 2017
    • 44
    [Error Code] FA14 in bizhub c308
    Hello guys!
    I have the error code FA14 in one bizhub c308 ! There is some firmeware to do !??
  • Woxner
    • Jul 2011
    • 843
    Re: FA14 in bizhub c308
    yes there are bulletins on this. could also be a few other things
    • tech51
      • 846
      As a minimum you will need to update the sata firmware and then update to the latest version of firmware.
      If that doesn't work then you will need to use the recovery firmware, following the tech bulletins to the letter, and then update everything.
      If that doesn't work it's likely the mfp will need to be replaced.
      That normally fixes it.
      • Shinigami
        • Mar 2017
        • 44
        Tanks bro i will try tomorrow!
