DV411 Trickery
  • allan
    RTFM!!
    • 5462
    [Misc] DV411 Trickery
    Any one else to comment on how handy a DV411 has become on things like DV311 and DV512's?
    Now really no need to buy and dev tanks??
    End off life reached before replacement...
    Whatever
  • Tech Helpdesk
    • Jul 2015
    • 112
    Re: DV411 Trickery
    We only use OEM toner and change the drums at 130%, this allows us to reset the units with the reset tool from Katun part number 48218
    We have tried the DV411 but you have to get the weights right , then reset the unit and yes it can work
    • REGSIS
      • May 2016
      • 435
      Re: DV411 Trickery
      Have anyone tried to put DV512K (whole unit) instead DV512C/M/Y? Developer should be the same, only toner colour is different.
      • Tech Helpdesk
        • Jul 2015
        • 112
        Re: DV411 Trickery
        Yes all you need to do is do about 60 A3 halftones at 255 and the correct colour would eventually come through.
        • REGSIS
          • May 2016
          • 435
          Re: DV411 Trickery
          Thanks, that's exactly what I thought. I'm asking this just in case of dev unit failure before EOL. Hope I won't need this.
