BH350 Fax Setting from e-mail to G3
  • AlSyed
    NewBee
    • Aug 2010
    • 41
    I have 2 BH350 copiers at clients. The default setting for fax is at email. I need to change it to Fax-G3 but it does not stay as default and client have to change settings every time.
    Your advise will be helpful please.
  • Synthohol
    Certified Konica Expert
    • 5868
    Re: BH350 Fax Setting from e-mail to G3
    IIRC its a setting in Admin mode.
    • AlSyed
      NewBee
      • Aug 2010
      • 41
      Thanks for the reply. I did try for quite long. went into Admin mode as well but could not find. If you please kindly share a bit more about the settings in Admin. Much appreciated.
      • Synthohol
        • 5868
        1. Touch the Utility/Counter-key.
        2. Touch the Admin. Management-key.
        3. Input the the Administrator code (12345678).
        4. Select the Admin.1 key.
        5. Select the TX Setting key.
        6. Select the Quality/Mode key.
        7. Select the Communication Mode key.
        8. Select the FAX Key and G3
        enjoy!
        and please consider contributing to this site.
        maybe if this site were self supporting they can dispose of all the annoying ads on this site.
