BizHub C220 Firmware, Please Anyone?
  • TheAlikA
    • Mar 2017
    • 9
    [Misc] BizHub C220 Firmware, Please Anyone?
    Hello, I have just purchased an old Olivetti d-Color MF220 which is the same as KonicaMinolta BizHub c220
    I'd really like to update it and start using it, but can't seem to find the right drivers and Firmware.
    I am using MacOS Sierra and got some generic drivers which don't even allow me to select the trey from which to print.
    As for the firmware, the machine is pretty "used" and will need replacement parts soon, so If possible a link to the latest firmware which can surpass the life of the consumables, if not, just the latest firmware would be greatly appreciated.
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Re: BizHub C220 Firmware, Please Anyone?
    I have it
    check below
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
    • copier tech
      • 8195
      The Postscript driver should allow you to choose paper trays etc.
      Did you try this one?
      Download Centre - KONICA MINOLTA United Kingdom
      • mak
        • Mar 2017
        • 2
        hello I also need firmware and movie data files to unlock the iu, dev unit, fuserunit, belt unit konica c280
        if any one have
        please reply me
        md.xerox@gmail.com
        thanks u
        • copier tech
          • 8195
          • TheAlikA
            • Mar 2017
            • 9
            • TheAlikA
              • Mar 2017
              • 9
              Originally posted by rapidocument
              I have it
              check below
              I have no Idea what i'm looking at, looking at your site is like jumping back to 1999, and you rightfully say so on your "blog" "times are changing": no links, no prices, nothing but a list of printer models and a contact form...
              ...Times are changing and it's time you get an update my frien'!
              • TheAlikA
                • Mar 2017
                • 9
                Works like a charm!!! I actually already had it installed but didn't realise you must select your driver, rather than let is be a "Generic Post Script"
                • jaderyan
                  • Apr 2017
                  • 13
                  Hello everyone,
                  please i need also the firmware update C6 for my konica c220, here is my mail if anyone can give : vjoffre83@gmail.com
                  Thans a lot
                  • Elmo
                    • Feb 2010
                    • 541
                    ok just try buying it from Konica Minolta
                    or as your is an Olivetti you need Olivetti Firmware
                    good luck with that
                    Using the latest firmware would allow you to prevent end of life parts stopping the copier
                    it will not fix the parts if they are worn out
                    I Used To Live To Fix Things Now i Fix Things To Live
