Konica menolta bizhub 652 printing parallel lines
  • khadimetareqat
    • Mar 2017
    • 35
    [Misc] Konica menolta bizhub 652 printing parallel lines
    sir
    i have trouble with my konica menolta bizhub 652
    my machine is printing parallel lines (when direct prints job is processed)
    i previously installed the firmware and refreshed the installed data and i cleared the nvrom.
    test page is normal
    print from pc is normal
    scan to PC is normal
    Scan to box is normal
    print from box also printing parallel lines.
    sir is this is license issue or any other configuration issue
    kindly help me?
  • Max
    • Oct 2011
    • 563
    Re: Konica menolta bizhub 652 printing parallel lines
    example?
    • darry1322
      • Oct 2010
      • 817
      If this is a color machine and the lines showed up after clearing NVRAM, you need to follow the setup instructions as if it was a new machine.
      • khadimetareqat
        • Mar 2017
        • 35
        sir kindly guide me what settings needs to change
        thanks
        • khadimetareqat
          • Mar 2017
          • 35
          example.pdf
          Originally posted by Max
          example?
          • khadimetareqat
            • Mar 2017
            • 35
            Originally posted by khadimetareqat
            [ATTACH]35885[/ATTACH]
            sir
            color mode:
            only color + full color mode is printing that (paralell)lines
            black mode cant print that lines.
            • darry1322
              • Oct 2010
              • 817
              That's the lines.
              Follow setup procedure and the lines will go away.
              I don't have the procedure memorized, but it's mostly :
              set time and date,
              adj touch screen (if available)
              set serial numbers,
              set unit replacement,
              gradation adjust
              getting it right is important.
