B227 Error code C-D313
  • erwinf
    • Feb 2016
    • 6
    [Error Code] B227 Error code C-D313
    hi Guys I have Konica Minolta B227 that keeps giving me the error code C-D313 and fails to boot up. has anybody had a similar problem or is there a firmware fix.
  • laitang
    • Nov 2012
    • 627
    Re: B227 Error code C-D313
    From SM:
    Trouble type CD3##: Nonvolatile data error
    Procedure:
    1. When a trouble caused by nonvolatile data error occurs, the screen below appears.
    • KMFLT3CH
      • May 2017
      • 242
      Got this code today on a C308, they had a dozen of the same code in the error code log for a couple of weeks.
      Executing the Recover Data as the machine suggests seems to do nothing, the machine does it's thing then reboots but gets stuck at the shark fins/pillars. Tried unplugging the HDD, swapping memory module, no luck it just won't boot up. The last step in the service manual points to replacing the MFP board so I am going with that and will write back with what I find.
      For forum search purposes:
      C-D313 CD313 D313
        [ATTACH=CONFIG]42647[/ATTACH]
        C-D313 CD313 D313
        1)this is diff model from the OP model
        2)thread has been dead for 2 years
        Please start a new thread
        • KMFLT3CH
          • May 2017
          • 242
          I'm aware, thanks
          The models are different, the code is the same and so are the solutions/relevant parts (word for word, if you compare both service manuals). This is more to document what I find so that if anyone searches/Googles this error code (like I did today) they will land here and hopefully get a fix. I don't see the point in starting a new thread, I'm not looking for feedback, just adding my experience with this particular code.
          • tsbservice
            Field tech
            • 8068
            I'm aware, thanks
            You've got the things right.
            Basically Phil has a point, but that's not the case in situation when we have experienced KM tech willing to share his knowledge.
            Keep us informed.
              Keep us informed.
              from his post.... where he claims not to have been looking for feedback:
              Executing the Recover Data as the machine suggests seems to do nothing, the machine does it's thing then reboots but gets stuck at the shark fins/pillars. Tried unplugging the HDD, swapping memory module, no luck it just won't boot up. The last step in the service manual points to replacing the MFP board** so I am going with that and will write back with what I find.**
              IMHO it looked to me to be him asking for feedback and not just posting for reference.. I couldn't expand his .JPG large enough without it going blurry...
              I know that not every function available on one model is on the next..
              But I digress ...
              • KMFLT3CH
                • May 2017
                • 242
                Oops, I had it displaying a thumbnail instead of the full screenshot. My original post is fixed now.
                Yeah, just sharing the knowledge
                • tsbservice
                  Field tech
                  • 8068
                  Just exactly my thoughts and I'm right behind you 99% of time asking for NOT posting in an old thread and NOT mixing machine models etc.
                  However, that's the first case a vote for solution like this based on my search and knowledge.
                  Imho, problem is same shared between models and there was nothing valuable to be found about that error.
                  • KMFLT3CH
                    • May 2017
                    • 242
                    Forgot to write back, but a MFP board did take care of this issue.
                    • tsbservice
                      Field tech
                      • 8068
                      Good to know, thank you.
