Bizhub C654e- Trying to understand autocolor issue
  • BCE75
    • Mar 2017
    • 3
    We are trying to reduce print costs in our dept. We print books that have a mix of black and white pages and color pages. We assumed the autocolor setting on our C654e would separate the two but it counts all pages as color, even the pages that only have black text on them. The black is set to black (K). Color is all CMYK. Is there a way to get the printer to print the black and white pages as black and white and only use color on the color pages? All books are made in Adobe Framemaker with are done in Adobe Illustrator or Photoshop. Books are exported as pdf using Adobe Distiller and printed with Adobe Acrobat. I have tried multiple ways of saving the pdf, different Acrobat settings, but I'm not getting anywhere. I feel there must be a setting I am missing. Please help!
  • Synthohol
    Certified Konica Expert
    • 5827
    Re: Bizhub C654e- Trying to understand autocolor issue
    there is a setting that helps posted here somewhere, i just install free Foxit reader and print the PDF from it. separates black and color clicks properly.
    • methogod
      • Dec 2008
      • 921
      with books, you have to set black detection, and it should automatically charge correct.
      But it looks at the entire sheet (11x17 or 8.5x11), So what we do is design is spreads, try to put color in blocks of 4 pages where clients needs it. With the fiery rips, we set the page rangs that are color, and set the entire job to greyscale. Force the lessor amount of wear on the equipment. But we dont pay per client, we look at it on large runs.
      As you get into better equipment the Fiery's will trigger color or B&W on our larger machines as long as black detection is set.
      • 907tec
        • 434
        Here is the description of ACS control from the Theory manual, for your reference.BHC654e ACS.pdf
        • methogod
          • Dec 2008
          • 921
          sounds like copying feature not printing feature. But not that familiar with 654 series.
          • B0265
            • Jan 2007
            • 718
            The RGB levels in the page must be equal otherwise the machine treats the page as color. In the "other" tab of the PCL driver you can set threshold values for converting to greyscale even if the the RBG % is different.
