Ineo +227 networking issue
  • Elmo
    • Feb 2010
    • 541
    #16
    Re: Ineo +227 networking issue
    Can you have a good look at the network port on the pc it has any damage it could be the cause
    I Used To Live To Fix Things Now i Fix Things To Live
    • emujo2
      • Mar 2017
      • 1580
      #17
      The only sure way to find what is happening here is to run wireshark and capture the network traffic as you place that PC on line. I would also suggest turning off all unused protocols 1 by 1 (IPV6, IPX, apple talk etc) to see if anything changes. Maybe if you can narrow it down to an SNMP or SSDP issue you can configure the PC in question to disable these settings. Emujo
      • Synthohol
        Certified Konica Expert
        • 5799
        #18
        or just explain its a PC problem the copier is fine.
        why are you jumping through hoops? do you provide their IT services?
        if not its not your problem.
        you would spend less time and money buying a USB to RJ45 adapter for 10 dollars and divorce this PC you married.
        • allan
          RTFM!!
          • 5462
          #19
          The same thing is going to happen...
          Whatever
          • Synthohol
            • 5799
            #20
            if that's the case then that takes the PC out of the equation right?
            then maybe the actual network drop? or port on the switch?
            • Pig
              • Mar 2017
              • 9
              #21
              Thanks everyone for your help so far. I only have a basic knowledge of networking so your suggestions have been much appreciated.
              We have reset the PC and it all seems to be working fine so far... We'll put the programmes back on one by one and check the printer status after each install.
              P.S. sorry for the triple post above, my reply wasn't showing up so I posted again.
