Bizhub C451 - slight magenta/cyan tint in solid yellows
  • Capodastra
    • May 2012
    • 58
    [Misc] Bizhub C451 - slight magenta/cyan tint in solid yellows
    I can't seem to get calibration right.
    There is a slight magenta and cyan tint (about 4%) in solid yellows, so I cannot print a solid yellow alone . . . anybody got any ideas . . . please?
    Barney
  • Albonline
    • Sep 2008
    • 1144
    Re: Bizhub C451 - slight magenta/cyan tint in solid yellows
    reset and stabilize. what have you done to try and fix it?
    • habik
      • 2013
      Remove belt and check if any of the first TR holders aren't snapped, whilst at it clean IDC and cavity of ITB. Clean laser windows and IU chargers and optics and glass and then do Initialise+Background Reset. Then gradations calibrations. Try to get it as close to zero on Highlights and Darktones in the conversion value section.
      Let us know from that point onwards what happened.
      Firmwares HERE
      • Capodastra
        • May 2012
        • 58
        Thanks for all your help.
        After numerous calibrations and adjustment sin Acrobat it has disappeared.
        BD)
