C227 copy menu default
  • DPSolutions
    • May 2015
    • 20
    Hi!
    How to set to display the copy menu when the machine is turned on?
    Now when the machine turns on, shows the home menu, where you can choose between copy and scan. I would like to avoid passing this screen to go to the copy menu.
  • kingarthur
    • 1324
    Re: C227 copy menu default
    it's in admin, "system settings", "reset settings" then you have "auto reset", change this to what you want
    • DPSolutions
      • May 2015
      • 20
      thank you very much !!!
