PRESS C5501 !!
  • Shinigami
    • Mar 2017
    • 44
    PRESS C5501 !!
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: PRESS C5501 !!
    check the gears 15 and 16, one is a one way gear that slips.
    sand down the shaft and clean the needle bearings with IPA.
    • Shinigami
      • Mar 2017
      • 44
      Re: PRESS C5501 !!
      I changed both !
      I do the test mode of I/O
      27-20 motor not turn ,Even if empty without gears !
      • Synthohol
        • 5892
        Re: PRESS C5501 !!
        ok, now its down to the connectors, motor or PRCB i believe.
        do you get 24v to the motor at all times? the prcb sends the ground to make the motor turn if memory serves.
        • Shinigami
          • Mar 2017
          • 44
          Re: PRESS C5501 !!
          I changed the PRCB AND THE MOTOR
          what about the ACDB ??
          • Synthohol
            • 5892
            Re: PRESS C5501 !!
            Error
            C-0213
            Root Cause
            C-0213 code when Start button is pressed at Ready or intermittently during operation.
            Workaround/Fix
            PROBABLE CAUSES:
            1. A one-way paper exit drive gear is slipping.
            Replace Paper Exit Gear/2 - 29T (p/n A03U 9098 00), Paper Exit Gear/3 - 23T (p/n A03U 9097 01), Paper Exit Gear/4 - 37T (p/n A03U 9096 00) and/or Paper Exit Gear/5 - 40T (p/n A03U 9095 02) as necessary.
            2. Dirty or failed Paper Exit Pressure Home sensor (PS10).
            Verify operation in I/O Check Mode, input code 27-25. Clean or replace PS10 as necessary (p/n 08AA 8551 2). Please refer to attached C0213 document for more detailed information.
            3. Paper Exit motor (M54) failed.
            Verify operation in I/O Check Mode, output code 27-25. Replace M54 (p/n A03U M111 00) if necessary.
            4. Open ICP2 (24V DC) on the ACDB.
            Replace the ACDB (p/n A03U H520 02).
            5. Original style regulating shaft is installed. (bizhub PRO C6500/C6500P/C5500 only)
            Install modified Paper Exit Regulating shaft (p/n A03U 8929 02).
            Note: Please refer to attached Parts Modification Notice and ExitSection parts document.
            6. The wiring for M54 has been damaged by the rear side of the paper transport section or rear section of the paper transport unit bracket contacting the harness.
            Inspect the wiring harness to M54 and replace as needed (p/n A03U N213 02).
            Note: Please review the attached WireDamage document for images of the wire harness and suspect section of the paper transport. Also, refer to attached C0213 document for more detailed information.
            this is all i have for ya, hope something helps!
            good luck!
            • afterhours
              • Mar 2017
              • 152
              Re: PRESS C5501 !!
              Solution ID TAUS0800312EN* Solution Usage 25
              Description
              Solution
              PROBABLE CAUSES:
              Replace Paper Exit Gear/2 - 29T(p/n A03U 9098 00), Paper Exit Gear/3 - 23T(p/n A03U 9097 01), Paper Exit Gear/4 - 37T(p/n A03U 9096 00) and/or Paper
              Exit Gear/5 - 40T(p/n A03U 9095 02) as necessary.
              Verify operation in I/O Check Mode,input code 27-25. Clean or replace PS10 as necessary (p/n 08AA 8551 2). Please refer to attached C0213 document for
              3. Paper Exit motor(M54) failed.
              Verify operation in I/O Check Mode,output code 27-25. Replace M54(p/n A03U M111 00) if necessary.
              5. Original style regulating shaft is installed . ( bizhub PRO C6500/C6500P/C5500 only)
              Installmodified Paper Exit Regulating shaft (p/n A03U 8929 02).
              Im a Loser Baby!!!
              • Synthohol
                • 5892
                Re: PRESS C5501 !!
                wish i'd said it first
