Bizhub C550 Error Code C3724 After New Fuser
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Error Code] Bizhub C550 Error Code C3724 After New Fuser
    We keep getting an error code C3724 on a bizhub C550 over and over and over. We have replaced the fuser unit multiple times yet it keeps coming back. Has anyone had this problem? Thanks in advance!
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • allan
    RTFM!!
    • 5462
    Re: Bizhub C550 Error Code C3724 After New Fuser
    How long between recurrences? could be bad mains power.
    Whatever
    • Woxner
      • Jul 2011
      • 842
      did you reset it right with trouble reset. there is a pwb that controls this. also might be the induction plate
      • MFPs R Now PCs
        • Jul 2011
        • 156
        It is 3-4 months in between and with a different fuser, it comes back 3-4 months later...?
        • MFPs R Now PCs
          • Jul 2011
          • 156
          Yep, we will reset it and maybe get several weeks, then a few, then 1-2, then days and end up replacing it. Then it starts all over again...?
          We follow the absolute strict recommended way of Konica Minolta's "Trouble Reset" procedure and add extra time to boot even, makes no difference.
          • allan
            RTFM!!
            • 5462
            As per Woxner try to replace that control print and coil.
            Whatever
