Konica menolta bizhub adf adjustments are unavailable
  • khadimetareqat
    • Mar 2017
    • 35
    HI DEAR
    MY KONICA MENOLTA BIZHUB DCOLOR 652 CANTS SHOWING THEIR ADF ADJUSTMENTS ,
    AFTER NVRAM REFRESH IT REQUIRED THE ADF ADJUSTMENT BUT ADJUSTMENTS MENU IS UNAVAILABLE , kindly guide me ?
    ADF is working , only adjustments menu is unavailable in both service and administrator menu/
    Ahmad shah
  • service_man
    • Jul 2012
    • 59
    Re: Konica menolta bizhub adf adjustments are unavailable
    Hello,
    Try to change the FW,
    Check the connector on the ADF.
    Regards
    • khadimetareqat
      • Mar 2017
      • 35
      ok
      sir their is only two firmwares are available for that machine
      can you send me the latest version of dcolor652
      thanks
      • Synthohol
        Certified Konica Expert
        • 5879
        it it a Bizhub C652?
        there are 33 base FW versions and 200 special.
        what ver do you have now?
        • khadimetareqat
          • Mar 2017
          • 35
          my current version is
          MFP Controler Boot program
          A0p00Y0-1E00-G00-02
          thanks
          • khadimetareqat
            • Mar 2017
            • 35
            MFP Controller BOOT Program A0P00Y0-1E00-G00-02(00)
            MFP Controller SubSet A0P00Y0-1F00-G00-14(00)
            MFP Controller A0P00Y0-0100-G00-D1(00)
            Operation Panel Message Data A0P00Y0-8100-G00-D1-100
            Fax Board Controller1
            Fax Board Controller2
            Scanner A0P00Y0-0023-G00-82
            Printer A0P00Y0-0050-G00-16
            ADF A0HT0Y0-0024-G00-04
            Finisher
            RU
            ZU
            Panel CPU A0P00Y0-8900-G01-01
            Loadable Device Driver
            Voice Data
            Movie Data A0P00Y0-A000-G00-03
            MFP Controller System A0P00Y0-1000-G00-D1(00)
            MFP Controller Print Controller A0P00Y0-3000-G00-AH
            MFP Controller Print Controller Font A0P00Y0-3F00-G00-35
            MFP Controller Print Controller Demo Page A0P00Y0-3E00-G00-01
            MFP Controller MIO A0P00Y0-5000-G00-27(00)
            MFP Controller PSWC A0P00Y0-5100-G00-20(00)
            MFP Controller MIB IF A0P00Y0-5200-G00-10
            MFP Controller IPP IF A0P00Y0-5300-G00-10
            MFP Controller Outside Controller IF
            MFP Controller TCP/Socket A0P00Y0-6300-G00-21(00)
            MFP Controller OPEN API A0P00Y0-7000-G00-13(00)
            MFP Controller Operation Panel A0P00Y0-8000-G00-D1(00)
            MFP Controller CSRC Control Body A0P00Y0-8300-G00-02(00)
            MFP Controller PIC A0P00Y0-8200-G00-A1
            • Synthohol
              • 5879
              is it a C652 or C652DS?
              • khadimetareqat
                • Mar 2017
                • 35
                its olivetti dcolor651 which is konica menolta dcolor 652
                • Synthohol
                  • 5879
                  if you print out a network config page, what model does it show? the "C652" controller or "generic"?
                  • khadimetareqat
                    • Mar 2017
                    • 35
                    generic 50C
                    • Synthohol
                      • 5879
                      Ok well thats an issue there.
                      There is a bit switch or 2 to change when you did the nvram clear for some unknown reason.
                      Solution
                      CAUSE: Incorrect settings.
                      SOLUTION: To change the Configuration Page header to Konica Minolta bizhub, please perform the following:
                      1. Access the Service Mode.
                      2. Select System 2.
                      3. Select Software Switch Setting.
                      4. Enter Switch No. "10".
                      5. Bin Assignment "00000000".
                      6. Hex Assignment "02".
                      7. Click on Fix.
                      8. Click on End.
                      9. Power the MFP OFF/ON.
                      also
                      switch 25 has to be set to whatever it was before the nvram clear.
                      then check system 1 marketing area and also make sure in system 2 the HDD shows as installed.
                      • khadimetareqat
                        • Mar 2017
                        • 35
                        sir in software swich
                        i perform that but their is below detail
                        5. Bin Assignment "00000010".
                        7. Click on Fix.
                        8. Click on End.
                        after that machine changed their bootup screen to konica menolta and lines issue is still their
                        i have a documnet about software switch setting kindly guide me a bout what another think to A0P00Y0-F000-G00-D1-100-CHECKSUM-6421.docchnage
                        • Synthohol
                          • 5879
                          what lines issue? we were discussing the unavailable ADF adjustments.
                          try following the initial setup to detail and exact order.
                          you will need 11x17 (A3) paper for the many gradations.
                          serial numbers, time etc...
                          just follow it from start to finish.
                          • khadimetareqat
                            • Mar 2017
                            • 35
                            yes
                            we were discussing adf adjustments
                            after that switch adf adjustments are also unavailable
                            hdd is instaled
                            gradation and serial number time and date setting is done
                            i think only adf setting is incomplete
                            • Synthohol
                              • 5879
                              try service mode system initialization system ERROR clear hit start then reboot when indicated.
                              see if that helps.
