Bizhub 210
  • doicho
    • Nov 2011
    • 13
    Bizhub 210
    I have a Konica Minolta 210. When the paper pass second time(manual duplex) the image is very light.
    In the single pass image is ok.
  • service_man
    • Jul 2012
    • 59
    Re: Bizhub 210
    Maybe is paper have huidity very high!!!
    Did you try with the another paper type?
    • doicho
      • Nov 2011
      • 13
      Re: Bizhub 210
      I try several type of paper and the result is the same. Whenthe paper pass through the copier the image on the second side always is very light.
      Ireplaced the entire right cover with transfer roller but problem stillstay.
      • service_man
        • Jul 2012
        • 59
        Re: Bizhub 210
        When the paper is coming on the second side, did you hear the sound of the HV from the Charging Corona?
        • Blizzoo
          • Aug 2013
          • 607
          Re: Bizhub 210
          Reshape the 2nd transfer contact spring leaf in the correct position.
