Konica Minolta C364 Light Copy/Scan
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta C364 Light Copy/Scan
    Konica Minolta Bizhub C364 getting Light Copy and Scan. From both ADF and Platen Glass.
    Cleaned the mirrors and glass. Print is fine. Any adjustments? Please advise.
    Thanks and Regards,
  • rrrohan
    • Sep 2011
    • 1977
    Re: Konica Minolta C364 Light Copy/Scan
    Do a duplex scan (assuming you have a DF701 and tell us if both sides look the same or if 2nd side is ok
    • mearmi
      • Oct 2010
      • 350
      Thanks for your reply. It is DF-624 and both sides are same.
      Regards,
      • Synthohol
        Certified Konica Expert
        • 5849
        hows the white strip under the glass?
        • mearmi
          • Oct 2010
          • 350
          It is clean and copier has done only 85K total.
          • paulrid
            • Nov 2011
            • 206
            Have you tried the gradation for copying?
            paul.
            • mearmi
              • Oct 2010
              • 350
              paul.
              Yes! Done it. still same
              • JR2ALTA
                • Feb 2010
                • 2033
                Change original type to text, and/or bump up exposure.
                • rrrohan
                  • Sep 2011
                  • 1977
                  Can you show us a sample
