konica minolta press c6000 black banding
  • rofield67
    • May 2014
    • 15
    [CQ] konica minolta press c6000 black banding
    Intermittent Black banding with dark 1 inch darker band on trailing edge. Banding shows on black half tones and darker band will show on non image area even on color monochrome test pages. If I open and close process assembly problem will go away for a short time, maybe a couple hundred pages. I have replaced drum, charger, developer and developer unit. I have attached picture of a test page 53 density 100, this page is usually very smooth without all the banding. Has anyone experienced this problem? Thanks!
  • khattab.al.masry
    • 212
    Re: konica minolta press c6000 black banding
    Ckeck corona assy. for black and change if needed
    تم الإرسال من SM-J700H باستخدام Tapatalk
    • rofield67
      • May 2014
      • 15
      replaced with new and also swapped with other colors, no change. Maybe arching connector on machine frame or bad HVT, HVT and connectors very difficult to access on this model, my have to try it anyway.
      • ITobiTA
        • Mar 2019
        • 4
        Does anyone find a solution for this Problem? i have seen 3 machines with this.
        Removing the process mount will solve this problem for a few days or hours. All machines got this just with the black color.
        Drum/Dev Unit/Corona are replaced with new ones. Same Situation
        Thanks!
        • kandod
          • Mar 2010
          • 58
          Is that the trailing edge? If it is the inboard edge instead, try putting some tape on the drum plate where it touches the dev unit yellow bearing (increasing a little bit the distance between the drum and the developer roll).
          • tulintron
            • Jul 2014
            • 668
            Good Morning. What is the size of the paper and what is the direction of the introduction?
