BH Press C7000 Touch screen inoperative after replacement & even before replacement
  • Desert Rat
    • May 2008
    • 1089
    [Electrical] BH Press C7000 Touch screen inoperative after replacement & even before replacement
    Here's how it started.
    My customer had a building built. They put in the Air conditioning one weekend. When I came in to service the machine
    I noticed a scratch on the touch screen. We would have to squeeze the panel in different places to make the selections
    needed for the jobs. Customer ordered the screen and I installed it. I tried to calibrate it but it would just beep without
    being touched. It did seem to work right after the install but was off as far as where you would have to touch it. That's
    why I tried the calibration. Now it's even worse.
    After looking through 275 posts from a search I saw some solutions.
    I do trust Hans, as I also contributed to the fix for those developer collars.
    But I like the idea of just using a mouse.
    Can anyone add to these fixes?
    DR
  • Synthohol
    Certified Konica Expert
    • 5814
    Re: BH Press C7000 Touch screen inoperative after replacement & even before replaceme
    honestly the first thing i would try is firmware.
    i've been pleasantly surprised before with stuff like this.
    • Desert Rat
      • May 2008
      • 1089
      Unfortunately as an indy I have trouble getting and downloading firmware.
      I just don't do downloads very often. But I can get help if I can get the firmware.
      Thanks for the quick reply
      DR
      • Desert Rat
        • May 2008
        • 1089
        It's not fixed yet. But I did find that I can use a mouse to select things on the control panel. And I also found out if I plug
        a usb key board in, the enter key acts like the start key. I have not found the stop or reset keys yet. So that's a little odd,
        but at least we are able to use the machine. And I can service
        it using these items. It takes a little longer but it works.
        According to Hytec I probably need the over all control board. I'm just waiting for my customer to order it.
        Also I did check the firmware and it seems to be up to date.
        DR
