Help c8000
  • Shinigami
    • Mar 2017
    • 44
    Help c8000
    Hello everyone !
    Can you help me ! I have this problem in konica minolta press C8000
  • Shinigami
    • Mar 2017
    • 44
    Re: Help c8000
    Up
    • Gaffers01
      • May 2011
      • 335
      Re: Help c8000
      fusing belt is knackered
      • Shinigami
        • Mar 2017
        • 44
        Re: Help c8000
        But i check it ! It's correctly installed
        • diananto
          Re: Help c8000
          Excuse me, is lower belt fusing its been replaced?
          Maybe I've seen the same problems before..
          The fusing lower belt was already saggy at the front and rear section,
          I tried to replace the part and the problem gone.
          diananto
          • Shinigami
            • Mar 2017
            • 44
            Re: Help c8000
            diananto
            I replace the fusing lower belt ! But the same problem
            • diananto
              Re: Help c8000
              In addition to lower fusing belt, which parts has been replaced?
              Upper roller and outside heater, already?
              maybe you have to replace the main fusing unit with the new one and
              elimination one by one where is the problem maker.
              I'm also still learning, just wanted to share a little, might help.
              • Shinigami
                • Mar 2017
                • 44
                Re: Help c8000
                thank you so much ! i will tray with the haeters ! And fusing roller
