Vendor Mode 2 limitations
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    mainly on the new 8 series though, its probably the same for the old machines too.
    Is there a way to restore multitasking to the machine in this mode, ie, being able to change into scan mode while a copy / print is being performed? I do not recall.
    Currently it will only allow you to do one thing at a time, though if i remember correctly thats just how it is...
    • 23009
    Re: Vendor Mode 2 limitations
    I found a bulletin on the bizhub 364e, that listed DIPSW settings to restore some of those functions. I'll see if I can locate it. =^..^=
    • Cantechman
      • Nov 2008
      • 228
      I had the issue of a c284e a couple of years ago, took weeks to get it sorted out. Here is a couple things to check that I recorded at the time.
      dip switch 30 bit 5 hex 20 enables multi job ability.
      when setting up key counter in vendor mode set next job reservation to license- default is ban.
      Try those 2 first to see if it helps
