C6500
+ More Options
Posts
  • afterhours
    • Mar 2017
    • 152
    C6500
    Hi all,
    I have a customer with a c6500. He has error C2451. We have swapped yellow developer unit but the code came right back. Any ideas?
    Im a Loser Baby!!!
  • afterhours
    • Mar 2017
    • 152
    Re: C6500
    Ok, So I know im replying to my own thread, but i just wanted to give an update to see if someone might be able to help. At this point, ive replaced yellow developer, swapped the developer unit, swapped drums, replaced printer controller board, and watch the developer motor turn. Is there anything else I could be missing? Please help...
    Emmanuel
    Im a Loser Baby!!!
    • afterhours
      • Mar 2017
      • 152
      Re: C6500
      I also noticed that when the machine malfunctions the yellow drum is completely covered in yellow toner.
      Im a Loser Baby!!!
      • HitMan
        • Aug 2015
        • 170
        I had an issue with magenta. When trying to complete an ACC an error would appear indicating the magenta ID sensor/ potential sensor. When I took out the ITB just after the error I could see a large portion on the belt that just had full magenta. To correct this I had to clean the ID sensors with alcohol. Also make sure the drums are properly lubricated and they turn freely.
        • Albonline
          • Sep 2008
          • 1154
          Re: C6500
          there is no charge on the yellow drum or no bias on the yellow developer. yellow is the first color checked during startup so it will trigger a yellow code if there are ANY problems with hv.
          • Albonline
            • Sep 2008
            • 1154
            Re: C6500
            • afterhours
              • Mar 2017
              • 152
              Re: C6500
              So do you recommend i replace the hv unit? or is there a particular contact that tends to "go bad"
              Im a Loser Baby!!!
              • afterhours
                • Mar 2017
                • 152
                Re: C6500
                Also, is it hv 1 or 2 that i should change?
                Im a Loser Baby!!!
                • rofield67
                  • May 2014
                  • 15
                  Re: C6500
                  Check the process unit connector for damage, it is located on the back of the process unit and also on the back wall of machine. You can try cleaning them with contact cleaner. Good luck.
                  • mircea
                    • Feb 2014
                    • 70
                    Re: C6500
                    check inside transfer belt to see if any transfer rollers came lose.
                    if developer is good, u already cleaned registration sensor.. this is the only easy option left
                    best of luck
