bizhub 652 shows error code C-4501 about 4 - 5 times a month
  • Laserbeam
    • Aug 2011
    • 152
    [Error Code] bizhub 652 shows error code C-4501 about 4 - 5 times a month
    Hello,
    a bizhub 652 shows regularly every few days, error-code C4501. After clearing the code, the machine runs completely normal for several days.
    This procedure is repeated every few days. According to the service-manual there is a laser malfunktion.
    Is it possible that the small sos-index-mirror in the unit is dirty?
    This error I knew from earlier models, such as Konica 9028.
  • Tech Helpdesk
    • Jul 2015
    • 112
    Re: bizhub 652 shows error code C-4501 about 4 - 5 times a month
    Originally posted by Laserbeam
    Hello,
    Best thing to do is pop a new laser in the machine, but you can try and clean the old laser and remove the polygon without touching the sides with your hands and apply a tiny bit of furniture polish on the hole for the air bearing and re-assemble like we used to on the old Konicas
    • Synthohol
      Certified Konica Expert
      • 5857
      IIRC there was a free of charge laser replacement program because they knew they had too many failures.
      When I get home I'll see if I can find a bulletin.
      O think it was the 2 series...
