Applying setting powder -- how exactly? how liberally, and to what?
  • jay3
    • Apr 2017
    • 46
    I'm replacing a transfer belt on a C6500 and noticed in the instructions (so far) to apply setting powder:
    - "before installing belt cleaner unit, apply setting powder to...* "
    and
    - "to half the area of the transfer belt* "
    Where * seems to basically be the large area of transfer belt between the belt cleaner unit & separation claw assy.
    I read elsewhere that if you don't have OEM "setting powder" (which I don't have) you can use OEM yellow toner (which I have plenty).
    But how... to apply? I've never seen this done before. Does anyone have a video? Or really good text instructions?
    Thank you!
  • jay3
    • Apr 2017
    • 46
    Re: Applying setting powder -- how exactly? how liberally, and to what?
    I think I did it right... but so far no good.
    C-4522 error upon reboot.
    Wiped the 2 sensors + gamma sensor with clean cotton cloth & rebooting again....
    • jay3
      • Apr 2017
      • 46
      Well... it works. Except there's some greasy scuffing track lines that you can see when the light hits prints a certain way.
      • ysshin79
        • May 2017
        • 37
        and
        Thank you!
        Yes. Yellow toner(6501 toner) apply. No problem.
          • 23008
          Setting powder comes in a cloth bag that you can tap directly on the drum or belt without any resulting damage. Each time you tap the bag to the surface it gives you a roundish puff of powder. I'll dust about 1/3 of the transfer belt, rotate it 1/3, repeat two more times. If you've ever opened up an OEM drum, they come pre-dusted, as a reference.
          If you're using yellow toner, put it in a salt shaker. Only you can't tap it against the belt.
          If the cleaning blade doesn't flip, you did it right. =^..^=
          • jay3
            • Apr 2017
            • 46
            Didn't flip .... but I wouldn't go so far as to say I did it right (see photo). Like your idea of salt shaker... thinking also maybe of one of those 99 cent store clear nozzle-tip condiment dispensers shake-up, puff a little out, repeat. Or thinking of how KM does it, maybe a satchel of some sort that allows it to puff out on same manner.
            I had basically committed to.... "I will probably need to buy another transfer belt, but here goes nothing...." I essentially did it pinching and throwing a little at it Emeril Lagasse style then dabbed very gently (bad) with my freshly gloved finger.
              • 23008
              Not ideal, but certainly adequate. Next time lay the belt assembly flat on the table. =^..^=
                i have seen some guys use their wives old panty hose ( foot section ) and doubled it up with powder inside and lightly tap on drum or belt.. then store the remainder in a small ziplock baggie
                • Desert Rat
                  • May 2008
                  • 1089
                  I use the Methuselah powder. It's alittle more expensive but it works great. A friend gave me half a bottle 3 years ago
                  and I still have about a quarter bottle left.
                  I have a very soft small cloth. Folded in fourths and I keep it in a zip lock baggy with some powder.
                  I can open the bag and tap on it and puff the powder out. It works so well I use very little. I can take the cloth
                  and gently wipe the transfer or drum blade for perfect pre-conditioning. A little more on the belt or drum, give it a turn
                  and you will notice how easy it turns and how fast it you get to that point where it turns easy.
                  I forgot where he got it at. I'll problably retire before I use it all.
                  DR
