Bizhub C227 scew adjustment
  • finni72
    • Jul 2010
    • 25
    Hi!
    I have some issues with the Bizhub C227.
    The customer complaining about scew copies and scan from the document feeder.
    I have tried the automatic feed adjustment, and adjusted the screw on the right hinge, but it doesn't help.
    I have adjusted the scanner scew, so the copy from the glassplate is perfect.
    Does any other of you have the same problem with this machine.
  • Max
    • Oct 2011
    • 546
    Re: Bizhub C227 scew adjustment
    Have you tried the height screws? Chances are one side of DF is higher than the other
    • finni72
      • Jul 2010
      • 25
      Thanx.
      Yes, I have tried to adjust the hight on the left hinge.
      Even when I try to adjust the scew max in both direction, it won't help any.
      • Woxner
        • Jul 2011
        • 826
        did you use the chart for the df skew adjustment.
        • finni72
          • Jul 2010
          • 25
          Yes, I used the Test Chart and the Installation manual.
