Oce' cm 3521 tranfer belt fuse
  • jper34
    • Sep 2011
    • 225
    Hi Folks,
    I have a customer with Oce" CM 3521 series, that she actually has a fuse to reset the tranfer belt assem., to clear the code.
    I went out, removed the belt, and trying to help customer, as the best seems fine, and not causing any copy quality issues. I just dont where the heck the fuse is located...? it looks like the :bus fuse" from a cars fuse box, from the past. they had other issues, that I took care of, but I'm not sure where this fuse is located, and will the copier eventually go into a code and shutdown the copier?...so any help greatly appreciated !!!
    Jaime
    Indep. Copier Svc.
    CT.
  • Synthohol
    Certified Konica Expert
    • 5806
    Re: Oce' cm 3521 tranfer belt fuse
    left side of the unit look for 2 gold square contacts. its behind that.
    may need a 00 phillips.
    • Desert Rat
      • May 2008
      • 1089
      That fuse is very low amperage. I usually get mine from Precision roller. Cheap for them.
      DR
      • Synthohol
        • 5806
        should be a 1/16 Amp (.063A)
