Bizhub c552 misaligned image
  • konica7022
    • Nov 2008
    • 132
    Hi guys
    C552 suddenly started give replace K drum / Set developer error
    so swapped few K IU units
    it works but now give prints like this
    i swapped Transfer belt, Cleaned the laser heads but no difference, Black print comes out fine but in color its out of focus miss aligned
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5806
    Re: Bizhub c552 misaligned image
    post a pic of the demo page from the engine.
    • konica7022
      • Nov 2008
      • 132
      • Synthohol
        • Mar 2016
        • 5806
        Looks like a slight skew is making it a registration issue.
        Reset the skew in service mode and do a manual registration adjustment.
        Clean the 2 sensors under the plate under the belt then adjust.
        Remember all colors use black as the reference point so there is none for black.
        • konica7022
          • Nov 2008
          • 132
          Thanks dude ... Resetting the Skew Sensors did the trick
          i did not set any of the registers manually
          Can i set the TSR sensor for the black manually to avoid getting error c2558
          PS; do you watch THE E X P A N S E series?
          • Synthohol
            • Mar 2016
            • 5806
            Originally posted by konica7022
            Thanks dude ... Resetting the Skew Sensors did the trick Awesome!
            i did not set any of the registers manually thats ok
            Can i set the TSR sensor for the black manually to avoid getting error c2558 why? if it cant replenish by itself there is another issue at play
            PS; do you watch THE E X P A N S E series? no, didnt get around to it.
            • konica7022
              • Nov 2008
              • 132
              I think it happens when i swap the Black IU from 452 to a 552 machine so i keep getting this error c2558, so i open and close the front door it starts working again some times i have to add black toner manually after a week or soo
