bizhub c258 with DF-629
  • marexim2000
    • May 2017
    • 16
    I installed a bizhub c258 with ADF model DF-629. I have a big problem with this ADF, it does not recognize paper. It need an initialization? Where is paper present sensor? Is possible it not work or is not on?
    I will attach some pics after I will convert its.
    Thanks,
  • marexim2000
    • May 2017
    • 16
    Re: bizhub c258 with DF-629
    Pics with DF629
    • Max
      • Oct 2011
      • 554
      Needs to be activated in service mode.
      • marexim2000
        • May 2017
        • 16
        "administrator settings" menu is the some whit "service mode"? In admin settings there is not setting for ADF or DF...
        • marexim2000
          • May 2017
          • 16
          I find "service mode" but I need password. Admin password is not some for this menu.
          • marexim2000
            • May 2017
            • 16
            Thank you very much. It was. I have activated and is OK.
            • marexim2000
              • May 2017
              • 16
              OK, first problem was fixed.
              I have second.
              Only in Copy mode:
              Even if the original page is white on the copy, there are some very thin lines of blue color on one side and red on the other side. Attached I put an example, but it's not really scanned, the lines are perfect.
              The print mode does not appear. Also scanned do not appear.
              What do you think it is?
              • REGSIS
                • May 2016
                • 434
                I have second.
                Only in Copy mode:
                It's a result of inapropriate instalation procedure.
                You MUST follow installation procedure step by step otherwise you'll get this lines in color copy as a result.
                  • 22999
                  You seen to have a reoccurring problem with reading installation instructions. =^..^=
                  • marexim2000
                    • May 2017
                    • 16
                    I don't have installation procedures. Can anyone send me?
                    Thanks.
                    • REGSIS
                      • May 2016
                      • 434
                      Thanks.
                      How? Instalation procedures are within the same box as new machine. Sometimes procedure is a bit different with different FW version, so if someone sends you procedure for function version 2 that might be the wrong one for FV3 and you get lines again after all.
                      • marexim2000
                        • May 2017
                        • 16
                        I have installation procedure for hard. I installed mechanical and electric all components , its is OK, but i don't have procedures for initialization, for registered in service menu and administration settings. I install optin DF-629, but until I declare it in service menu it does not work, after it it work perfect. I think I need to made other few settings or initialization procedures to disappear that cyan and magenta lines.
                        • mthomasebs
                          • May 2017
                          • 65
                          You need to complete the basic setup.
                          For the Cyan/Magenta lines to disappear, you need to enter the following in service mode:
                          (Bare in mind, in recent firmware versions, you can access a setup wizard by entering service mode and pressing STOP, 3. This brings you to the following necessary steps, although they can be done separately.)
                          • Date/Time - This can be done by entering service mode and pressing STOP, 1, 1, 4, 4, C.
                          • Serial Number Input - ADF Serial Number and any other options if you'd like.
                          • Unit Change - For confirmation that this setting has been checked, you need to simply switch one from User to Service and back again.
                          • List Output - Print at least the 3 options on the left hand menu.
                          • allan
                            RTFM!!
                            • 5462
                            Really do you need to print a list?
                            Whatever
                            • mthomasebs
                              • May 2017
                              • 65
                              Yup, its a management/adjustment list. Used for troubleshooting issues, but a lot of people throw this away.
