tcr iu c and y problam
  • saeidss
    • Jul 2015
    • 30
    Hello friends
    I have two images c452 series in the novelty of years ago I bought
    I threw the device
    Density 12 reding and y 4 density
    help me tanks alot
    Re: tcr iu c and y problam
    WOW we have had some threads that gave very little info as to the problem.. but you Sir have given the least that I remember..
    what is the problem...
    do you have printouts you can share showing it?
    what have you done?
    life of consumables?
    help us help you
    • saeidss
      • Jul 2015
      • 30
      whyyyyyyyyy
      help
        Originally posted by saeidss
        whyyyyyyyyy
        help
        WHY? what the questions?
        do you go to the Doctor and say " it hurts" but give no further info than that?
        are you a tech or an owner?
        you want help but do not supply info...
        done maybe someone will help.. even the title of your post makes no sense
        • Synthohol
          Certified Konica Expert
          • 5849
          i understand a language barrier but his posts sound like a stroke victim.
          it's a c452, put it out of its misery already!!
          • konica7022
            • Nov 2008
            • 132
            Mind you there are parts of the world where c452'z are still worshiped
            • saeidss
              • Jul 2015
              • 30
              hi stock image tcr level 12 and 17
              • habik
                • 2013
                Pull all IU's out of machine and give it a good shake. Then put them back in. If it doesn't cure then do Image Stabilisation Background Reset and Stablisation. Then Stabilisation + Gradation adjust. Do for each mode at least 3 rounds. Good luck.
                I usualy keep TCR to zero!
                Gradation Adjustments with Highlights below 60 and Halftones closest to 0.
                Firmwares HERE
                • saeidss
                  • Jul 2015
                  • 30
                  not work
                  why
                  • saeidss
                    • Jul 2015
                    • 30
                    what have you done?
                    help us help you
                    hello
                    My two friends had one machine broke down.
                    I got this andakhtm corrupted iu this device one device and this problem before the prologue
                    The friends do not have chip images
                    Now I don't know what to do?
                    Sorry English is not good
                    tnx
                      • 14813
                      hello
                      tnx
                      Type it in your own language and we can try to translate it. I have read the entire thread and still don't know what the problem is.
