bizhub c652 color image blure in black color
  • khadimetareqat
    • Mar 2017
    • 35
    Hi dear
    my konica menolta bizhub c 652
    printing Blur image in color prints and its black color
    in black color mode prints are fine
    its issue arise after 3 thousand of color prints with in 3 days.
    kindly guide me
    thanks
  • konica7022
    • Nov 2008
    • 132
    Re: bizhub c652 color image blure in black color
    do initialization and calibration once
    also print the demo page and post it here
    • D_L_P
      Self Employed
      • Oct 2009
      • 1196
      Generally, when copies are fine in b/w but have an issue in full color its a sign your transfer belt and 2nd transfer roller are at the end of their life. A little more info and samples would be appreciated.
      • Synthohol
        Certified Konica Expert
        • 5823
        have you cleaned the lasers? the coronas? and yes, samples would be ideal
        • khadimetareqat
          • Mar 2017
          • 35
          Sample
          • khadimetareqat
            • Mar 2017
            • 35
            when i print that image in B/W then prints are fine
            i cleaned the corona, but i don't have laser cleaning tool.
            theire is temperature change with in two days.
            and 2 days ago i refill the magenta cartridge with compatible toner.
            • Synthohol
              • 5823
              non OEM toner? sorry cant help.
              • D_L_P
                Self Employed
                • Oct 2009
                • 1196
                Originally posted by khadimetareqat
                Sample
                That is a color registration issue. Clean the color reg sensors and do the adjustment in service mode. If you want to go the extra mile, remove the transfer belt and clean the roller that drives the belt.
                • khadimetareqat
                  • Mar 2017
                  • 35
                  issue is solved automatically
                  i think their was the temperature change in environment.
                  thanks for guidance
