bizhub 920 c41-02 @ 41-01
  • mircea
    • Feb 2014
    • 70
    Hello.
    I've been strying to solve this problem for the last 4 days and i dont have any new ideas.
    I have a bizhub 920 with c41-02 code and it sometimes gives 4101 code too.
    already replaced:
    Printer control board (PRCB)
    DC power supply /1 (DCPS1)
    AC drive board (ACDB)
    Overall control board (OACB
    High voltage unit /1 (HV1)
    Scanner drive board (SDB)
    scanner home sensor
    scanner motor
    DC power supply /2 (DCPS2)
    and whole laser unit.
    can any1 please give me any new ideas?
    I\m realy out of ideas .
    thank you!
  • mircea
    • Feb 2014
    • 70
    Re: bizhub 920 c41-02 @ 41-01
    Originally posted by mircea
    Hello.
    already replaced:
    scanner home sensor
    scanner motor
    thank you!
    closed.. solved this
      • 22954
      If I may ask, How did you solve it? =^..^=
      • mircea
        • Feb 2014
        • 70
        after i replaced all boards i wanted to just give up.. but after i put everything together i powered copier with adu out and it works just fine..
        looks like it was a false code 4101 and 4102...
        lase unit and scanner unit had nothing wrong.
        there were 2 ipcs blown on 2 different boards.
        i put all old boards on another bizhub 920 and there was no code.. only close front door error.
        I will replace it anyway with a 950 since it is old and did its job good for a long time. (20m+ pages printed)
        Problems tend to solve the moment u are ready to give up!
