Registration from pdf files is not good
  • Capodastra
    • May 2012
    • 58
    [Misc] Registration from pdf files is not good
    Any pointers please.
    Here is a scan of a pront where the registration points are all pretty good but the black is way out of register.
    From InDesign I can create a postscript file of the original layout and it is OK, but if I create a pdf of the same file and place it in INDesign creating another postscript file the registration is bad.
    The print herewith was a pdf of the original file (which I had intended to print 2-up A4) placed in InDesign and then a further postscript file created to the Fiery and the registration is bad.
    My question is: Could it be the Fiery or the printer?
    ANY help please . . .
    Barney
  • allan
    RTFM!!
    • 5462
    Re: Registration from pdf files is not good
    Try the file with another PS printer or bypass the fiery to check.
    Whatever
    • Synthohol
      Certified Konica Expert
      • 5851
      the black looks fine to me, what you are missing is trapping.
      • Capodastra
        • May 2012
        • 58
        Sorry, I do not agree about black looking fine- the registration is miles out.
        It only happens with PDF files.
        • Synthohol
          • 5851
          just to be specific, you are talking about the white border all around the solid black letters and images?
          if it was registration there would be bleed-over on one side, the "halos" are even all around which is poor trapping.
          if you are seeing something else please point it out.
