Konica Minolta Bhc 7000 stays warm and does not fail
  • venetech
    • Mar 2017
    • 7
    [Misc] Konica Minolta Bhc 7000 stays warm and does not fail
    I have a Konica Minolta Bhc7000, the same gets ready, but when making several impressions gives the message "wait a little, the machine is heating up". And so it stays all the time and it does not give fault code, I'm a Venezuelan technician, thank you very much s help, Regards
  • tonymac
    • May 2017
    • 2
    Re: Konica Minolta Bhc 7000 stays warm and does not fail
    most likey its the upper fuser lamp causing that problem. you might want to try to clean the thermistors also.
    • Jimmy:)
      You can probably do a couple of things.
      Try to remove all finishers and see if you get the same issue.
      Also try changing software sw settings in the service mode
      19-1 to 1
      19-2 to 1
      19-3 to 0
      Hope this helps, I had the same issues and this solved it on our end but there are many different "Please wait signs".
      Good luck
      • venetech
        • Mar 2017
        • 7
        Replace, fuser lamps, thermistors, fuser band, and still the fault
        • Synthohol
          Certified Konica Expert
          • 5847
          warm up is not just heat, its also self calibrating. clean your ITB/Reg sensors. make sure the belt isnt wrinkled or wavey.
          • ysshin79
            • May 2017
            • 37
            I had two cases.
            The warming up was continued on the C6501.
            It is under the fusing unit.
            65AA 5365 1 - FIXING LIMITER
            In the C7000, the PHOTO SENSOR was replaced at the bottom left of the fusing unit gear assembly.
            08AA 8551 2 PHOTO SENSOR
            A50U M555 00 PHOTO SENSOR
            You can order any of the sensors above and replace them.
            • venetech
              • Mar 2017
              • 7
              Ready, replace ps16 and limiter fixing, resolved the fault, many thanks, Regards
