Firmware Imaging Toolkit, Firmware A00H0Y0-F000-GCQ-J8(00) - C550
  • bammes
    • May 2017
    • 4
    [Misc] Firmware Imaging Toolkit, Firmware A00H0Y0-F000-GCQ-J8(00) - C550
    Hello!
    I've bought a used C550 und added a Fax card FK-502.
    To make it work I've got to activate it in Service Mode but it's locked with a CE password.
    The company I bought it from doesn't seem to know the password or doesn't want to give it to me. I've already tried default pwd. and 8x0 and 12345678.
    Could someone please send me the firmware imaging toolkit together with the NVRAM reset firmware for this machine (should be A00H0Y0-F000-GCQ-J8(00) ) and maybe the latest firmware available?
    email: bammes at netzbusiness.net
    Thank you very much
    Thomas
  • KMFLT3CH
    • May 2017
    • 240
    Re: Firmware Imaging Toolkit, Firmware A00H0Y0-F000-GCQ-J8(00) - C550
    The CE password for that model should be 92729272.
    • bammes
      • May 2017
      • 4
      That's the default password I mentioned. Unfortunately doesn't work...
      • Nommo
        • Apr 2014
        • 27
        There's posibility to reset CE password by KM LMS site, but you will need technician aswell.
        If you will find NVRAM firmware read carefully all the instructions, cuz it's easy to do smth wrong (after NVRAM you need to enter serial numbers, get rid of license error and change Software Switch to correct value).
        Also take into consideration that it will reset all settings / counters etc.
        • Woxner
          • Jul 2011
          • 850
          see if somepne made it 9272927292729272
