C6501 Cyan Drum Keeps failing at 80% range...
  • methogod
    • Dec 2008
    • 915
    [CQ] C6501 Cyan Drum Keeps failing at 80% range...
    second PM Cycle where the Cyan drum fails early... Machine has 5M on it, but has a ton of replaced parts....
    Any suggestions, I am not sure where to start....
    I normally can let the DU-104s go till 120% PLUS before quality issues start....
    thanks,
  • methogod
    • Dec 2008
    • 915
    Re: C6501 Cyan Drum Keeps failing at 80% range...
    Images for reference....
    Just don't understand why the cyan fails at 1/2 its rated life...
    • mircea
      • Feb 2014
      • 70
      [ATTACH=CONFIG]36707[/ATTACH][ATTACH=CONFIG]36708[/ATTACH]
      are you sure there is no dust under the developer unit's doctor blade?
      also how i solved a problem with magenta drum that kept on failing long before 80% was by replacing hv detecting sensor and there were few leds not working right so i just replace all process unit. 2m prints later and still working fine.
      • methogod
        • Dec 2008
        • 915
        Dust would make lines the other direction...
        100% FAILED DRUM, just replaced and back to 100%.... failed at 82% last one failed at 85% or so.... Used to go to 150 without issue...
        Watching it like a hawk now...
        How do i test HV assembly? How do i test LEDs?
        Is there a test pattern?
