Bizhub C280 copy & scan skew problem
  • mkarip
    • Feb 2010
    • 33
    Dear Friends, we have following Problem
    Copier: C280
    Internal Prints: OK
    Copy & Scan from glass & ADF both skewed see picture
    exchanged whole scanunit with a working one, same issue
    Thanks for your help in advance
  • allan
    RTFM!!
    • 5462
    Re: Bizhub C280 copy & scan skew problem
    Did you change the entire top piece?
    Whatever
      • 23010
      Well it seems to me like your enduser has been leaning on the scanner, and bent it. If it were me I'd give the copier a bear hug.
      What you do is wait until the enduser is looking the other way, then loop your left arm under the scanner. Slowly lift the copier off it's wheels, then let it down. Make a test scan. Repeat if necessary.
      On your invoice write "Adjusted optical skew." and don't tell the enduser how you did it, but do suggest that they stop leaning on the copier. =^..^=
      • mkarip
        • Feb 2010
        • 33
        yes
        • HuronMan
          • Jul 2009
          • 68
          Did you try a different paper tray?
          • mthomasebs
            • May 2017
            • 65
            Its a scanner issue, why would you use a paper tray?
