BH-C-353, TB ruptured
  • Hansoon
    • Sep 2007
    • 3389
    BH-C-353, TB ruptured and CYM drums destroyed. Any known reason why this can happen with less than 200K? There is a TB blade flip but I'm not sure if that happened before or after the calamity. See attached pics.
    What can cause a TB to become that much damaged?
    Hans
  • lazymangr
    • Feb 2017
    • 115
    Re: BH-C-353, TB ruptured
    i have seen damaged transfer belts but nothing like this. the leftover toner means that the cleaning blade didnt work. maybe paper passed through it? i have seen more than 1 time, customer uses normal trays for labels and they got stuck on it. but i have no idea what caused the rupture.
      • 14812
      C353 transfer belts are only rated for 150k yield. That could have contributed to this failure.
        • 23009
        I've seen a few catastrophic failures on C554e but I attributed it to the huge volume of printing going through this particular machine. The blade was also flipped on mine, but I could not determine if it was a cause or an effect:
        • allan
          RTFM!!
          • 5462
          I don't know, golf balls and razor blades?
          Frustration?
          How long did it run like that?
          Whatever
          • allan
            RTFM!!
            • 5462
            If that bead on the inside of the belt goes...
            Caught one just in time.
            Had one a couple of days ago. But still why?
            Whatever
            • Hansoon
              • Sep 2007
              • 3389
              Anyone having for me the bulletin pertaining service code C-2152 and the modification of the slider on the TB please?
              Hans
              • allan
                RTFM!!
                • 5462
                Did it come loose?
                Whatever
                • Hansoon
                  • Sep 2007
                  • 3389
                  Allan, sorry pal, I don't know what "bead" you meant, thought you where joking or sipping too much of that fine South African wine. LOL
                  What bead can come loose?
                  Hans
                  • Nommo
                    • Apr 2014
                    • 27
                    Hans
                    Take a look at your PMs
                      • 23009
                      I think allan means that 7mm wide plastic strip on the edge of the belt, and it's seamed at some point, the vulnerable spot. =^..^=
                      • habik
                        • 2013
                        As to that bead, yes that is the strip which can come loose when the belt gets its wear in the nicer scenario it just wraps around a drum. In the bad scenario it goes anywhere.
                        How does the K - 1st transfer roller *(TR) on that belt looks like? Any damage on the bushings for any of the first TR's
                        What is the coverage of colour? Is the belt set to BW or Colour Priority?
                        Firmwares HERE
