Question at End of Every Operation
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Misc] Question at End of Every Operation
    We have a bizhub C552DS that is asking with a Yellow Triangle Exclamation Mark on a White Background "Do you wish to continue to use the destination and Job settings?" after EVERY Copy, Scan and Fax job initiated. I have never seen this before. I have looked at different settings under User and Administrator as well as reset to Factory Default the Default Copy Settings and Default Scan/Fax Settings under User Settings. I have even reset Network Setting Data, Copy Program Data and Address Registration Data in tech mode under System 1/Initialization. Where do I turn this off? Thanks in advance!
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • B0265
    • Jan 2007
    • 718
    Re: Question at End of Every Operation
    Check this setting:
    [Utility] - [Administrator Settings] - [System Settings] - [Reset Settings] - [Job Reset] - [Next Job]
      • 23008
      Many Kyocera's do this: Are you sure? Are you sure? Are you sure?
      YES! I'M SURE! =^..^=
      • MFPs R Now PCs
        • Jul 2011
        • 156
        Originally posted by B0265
        Check this setting:
        That was it! I thank you for your time and advice, it is much appreciated.
