We have battled for a while now with these $$$ ADF feed assemblies. We clean them and they work for a while, then problem re-occurs and we replace them with good results. (no data shown on rated life)
Have inspected both units and they appear exactly the same ( 2 different part #s and C3351 is yet another part #)
Another sticking point is the 2 small black levers at the top they can be knocked loose too easily.
We have a fairly new C3350 that they called in for noise.... It was the feed assembly attempting to lift. Put a new assembly & pad in it and it tested fine. Got a call for "broken" part Friday and it was the 2 small black levers had popped loose. Then, they are saying that it is still makes the noise. ( I did not duplicate while there though)
Rant over !!
Rant over !!
