Konica c220 email subject
  • barber782
    • Aug 2011
    • 286
    Hi guys,
    I've setup scan to email on a c220, everything works fine, but when the email comes through in the subject bit of the email it displays the model and name of the person. The sender address is fine. Where would it be getting this subject text from? I have checked the usual places in machine settings and smtp settings, but cannot see anything.
    Any help would be great
    Sent from my GT-I9195 using Tapatalk
  • emujo2
    • Mar 2017
    • 1579
    Re: Konica c220 email subject
    If authentication is enforced and you have email address listed in the user registrations, and the from address is set to "Use logged in user" (Admin/System/Restrict User Access), then I would expect to see the email from this user. Possibly you have the subject line defaulted to what is typed in here...You could set the scan settings back to factory and see if anything changes. There are also some scan settings in the Web Page that can add stuff to the subject line. Emujo
    • KMFLT3CH
      • May 2017
      • 242
      Give this a shot:
      From the fax/scan screen, select Communication Settings > E-mail settings > edit the Subject, From and Body text on this screen and then Close.
      Try scanning again and see what it shows in the inbox.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        If smtp authentication is enabled the machinr ignores the custom subject entries. Not sure if fixed in latest fw but this was a known issue.
        • barber782
          • Aug 2011
          • 286
          Solved. thanks KMFLT3CH
            ok glad you got it fixed.. what was the issue?
