Bizhub 454 and 454e
  • devontug
    • Apr 2015
    • 99
    [Misc] Bizhub 454 and 454e
    Is there a way to remove the card reader authentication totally from my machine?
    When I send a print it it says error deletion
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5892
    Re: Bizhub 454 and 454e
    Look in administrator settings then security settings turn everything off.
    Check software switch 12 should be set to all zeros then hit fix.
    • devontug
      • Apr 2015
      • 99
      Will do that now and let you know
      • devontug
        • Apr 2015
        • 99
        When ever I send a print I'm getting error deletion
        • mthomasebs
          • May 2017
          • 65
          If using a card reader check Service Mode -> STOP, 9 -> Authentication Device2 -> Unset.
          Check Utility -> Administrator Settings -> User Authentication/Account Track -> User Authentication -> either ON (MFP) or OFF. Switch to OFF.
          Check Utility -> Administrator Settings -> User Authentication/Account Track -> Print without authetication > Restrict.
          One of these should help.
          • devontug
            • Apr 2015
            • 99
            Got it to work thanks guys for all the help
