C35+ missing imaging unit message.
  • barber782
    • Aug 2011
    • 279
    Hi,
    Got a c35 that keeps displaying 'imaging unit missing' and shows all colours. Iv rechipped the drums to see if it clears but no joy.
    Replaced toners and nothing.
    Any help would be appreciated.
    Machine has done 90k
    Sent from my GT-I9195 using Tapatalk
  • mthomasebs
    • May 2017
    • 65
    Re: C35+ missing imaging unit message.
    Originally posted by barber782
    Hi,
    This can be an issue with the toner/image unit metal contacts, sometimes if they are dirty or bent, causing a poor connection they can throw up an error for all IUs.
    I'm not guaranteeing this is the issue though.
      • 22934
      For starters press the yellow triangle symbol to determine which color imaging unit that you need to investigate. =^..^=
      • MORGY
        • 38
        Hi,
        I had the same issue with 3 x same models. I replaced all image units and was still the same. After firmware upgrade all was good.
        • barber782
          • Aug 2011
          • 279
          Displayed all units. Solved. Was the magenta image chip. Replaced from a working machine and all OK.
          Thanks all.
